Results 11 to 13 of 13
October 11th, 2010 10:26 AM #11
October 11th, 2010 10:12 PM #12
October 12th, 2010 12:17 PM #13
suy,
ano nga ba makina mo brad?
as per my info, hindi na kailangan iadjust ang mga automatic lash adjuster.
just run them for 30 mins with 5 sec cycling to about 3k rpm to bleed the air out of the engine oil.
but if the mechanical valve mechanism, you may diy given the required tools. madali lang yun kung tutuusin.
the "tok" sound if it sounds only once every acceleration, better check your driveline. or engine mounts.
but if "tok" sound all throughout, check valve train system.
sana nakatulong. and i'm a little bit of outdated pagdating sa mga new engines. been tinkering all the time with old school engines esp diesels
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
