Results 11 to 17 of 17
- Jan 2007
- 137
June 13th, 2011 12:39 AM #11try replacing the rad cap sir , maybe the culprit.also the thermostat maybe malfunctioning, also check the rad fan and auxillary fan,leak from the water pump or hose. hth
June 13th, 2011 12:40 AM #12
ipasilip mo na para sigurado. puwedeng mahina na ang rad fan or may bara.
pag ok ang cooling, mabilis man ang takbo o kaya super trapik at mainit sa labas, hindi gumagalaw ang needle sa typical na puwesto.
- Jan 2011
- 262
June 13th, 2011 10:39 AM #14Thanks for the replies sirs, I'll have it check this weekend. Thank you for enlightening me, at least I know the car is not yet overheating. BTW sir can you fill this up for me?
Rad Cap = Federal Mogul (150 php)?
Rad Fan = ??? (new or surplus)
Aux Fan = ??? (new or surplus)
Thermostat = OEM (1200 php)
Thermoswitch = OEM (1300 php)
Am I correct with the estimates? From what I have read ganyan ang price ranges eh..
For the fans, what would be more cost effective? New or surplus?
- Jan 2007
- 137
June 13th, 2011 05:08 PM #15try mo muna ang pinaka madali at pinaka mura which is the rad cap, then the rad fan and aux fan makikita mo naman kung mahina ang ikot, tulad din ng saggustion nila baka may loose wiring lang magastos kung palitan mo lahat kahit na gumagana pa. surplus or replacement, it all up to you sabi na iba mas maganda ang surplus yung iba mas maganda daw ang brand new or replacement,depende na yan sa budget mo and how long you will keep your ride.
June 13th, 2011 05:20 PM #16
aux/radiator fan (surplus) = P500
generic sanden-type fan (brandnew) = more or less P600 sa auto supply.
brand new radiator fan = more or less P1k sa auto supply.
- Jan 2011
- 262
July 11th, 2011 11:47 AM #17Update lang mga sirs, I changed my rad cap to a federal mogul brand with a 0.9 psi rating, but still nagbabawas ng tubig sa reserve tank.
I just noticed the other day that the water inside my radiator has some slight rainbowish color, it looks more like a rainbow swirl to me. Could this be a sign of a busted cylindrer head gasket? Should I replace it ASAP?
I'm not overheating naman. Sometimes my temperature goes up above half but (a bit higher than the midway point but not up to 3/4) goes back to half after a few seconds.
I popped up the hood a day after I noticed the rainbow swirls and took the radiator cap off, I used my flashlight to take a closer look inside my radiator. The presence of the rainbow swirls was not present but I saw some tiny specks. It doesn't looks like rust to me. I also checked the water inside the reserve tank but there are no rainbow swirls in there.
How can I know if this is really oil in my radiator? I need you help badly before I make some drastic moves. Thanks!
1
