Results 1 to 6 of 6
- Mar 2004
- 89
April 18th, 2004 01:58 AM #1ok lang ba magkabit nang simota or nang k&n sa revo na 1.8? what are the pros and cons?
sa mga naka 1.8 na revo, ano mileage nyo pag city and long drive?
TIA....
see you guys sa transport show
April 19th, 2004 09:36 AM #2
mileage? afaik, wala namang magiging significant changes yan. merong small changes sa power, pero sa gas consumption, baka wala.
- Jul 2003
- 573
April 23rd, 2004 12:53 AM #3kung carburated engine, meron effect ang air filter sa gas consumption at fuel air mixture proportion
- Feb 2004
- 129
April 24th, 2004 07:41 AM #4Yep, tama sila na sa high rpm lang makita ang improvement ng engine breathing.
Kung carb yung makina, posibleng mag-lean out yung mixture(improved fuel efficiency), pero konti lang. Kung EFI, wa epek kasi calculado na yung fuel na ini-inject depende sa reading ng Mass Air Flow sensor, kayat kung may dagdag hangin na dumaan dahil sa mas maluwag na air filter, nag-compensate naman ang ECU sa pag dagdag ng konting fuel sa injection, kayat ang resulta, more power/same fuel efficiency.
April 24th, 2004 03:09 PM #5
there's a little effect on gas consumption, theory is the more air he better the burning of the fuels... so yun konting rev mo all fuels are really burnt up. Walang sayang... if you're going to install mass flow filters better upgrade din yun spark plugs and hi-tension wires. K&N filter costs around 5500, simota 500. ang layo no?! hehehe.. anyway i hav both if you're interested...
- Mar 2004
- 89
April 26th, 2004 12:04 PM #6mr sync3,
MAy mounting ka na nung k&n? kasi stock to lahat.... except for sparkplugs... i have platinum plugs.... baka meron ka nang apexi? kasi mas ok daw performace nang apexi interms of filtering.... pero yung boost nila parehas lang..... I was looking at the set-up and i noticed that i can remove the can holding the air filter... tapos install tha filter to the original inlet kasi pareho sila 3" diameter na butas.
samin doc sinasabihan kami "mag nilay nilay" - be quiet. Bawal magsaya (common sense) and music or...
Traffic!
