Results 1 to 4 of 4
    Suzuki/Tsikot folks, your comments/suggestions are highly appreciated.
    May iniwan sa akin na Suzuki Multicab dropside 4x4 pick-up, 3cyl, 12valve, 660cc, reconditioned ito galing japan. Matino pa yung unit, mga 1 week ko na ring gamit, malakas ang makina, madali istart kahit malamig.
    Eto ngayon ang napansin ko. Everytime na umaandar, may hangin na lumalabas sa [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]radiator[/FONT][/FONT][/COLOR][/COLOR] overflow tank. Pag binuksan ang rad cap, mapapansin ko na may air bubbles sa tubig. Hindi naman gaano kalakas ang air bubbles pero mapapansin mo kahit papaano.
    Eto yung mga initial checks na ginawa ko.
    1. Na check ko langis, ok naman, hindi kulay gatas, katatapos din lang pala mag [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]change [/FONT][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]oil[/FONT][/COLOR][/FONT][/COLOR][/COLOR] nito last month as per owner, Castrol oil gamit.
    2. Hindi naman nag ooverheat, wala namang halong oil ang tubig sa radiator(naka [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]Prestone[/FONT][/FONT][/COLOR][/COLOR] at distilled water mix yung radiator). Hindi rin nagbabawas ng tubig sa 1+ week ko ng gamit.
    3. Hindi nagbabawas ng langis.
    4. Malakas humatak kahit ibabad pa sa akyatan.
    5. Wala rin [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]oil [/FONT][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]leak[/FONT][/COLOR][/FONT][/COLOR][/COLOR] sa makina.
    6. Sinubukan ko buksan yung oil cap habang umaandar, wala namang usok kahit irev pa yung makina(blowby).
    7. One click pag mag start kahit sa umagang malamig.
    Ano kaya itong air bubbles sa radiator na nakikita? Normal lang ba ito o baka kasi major problem ito just waiting to be discovered. Mabuti na yung maagapan.
    Thanks in advance.
    Dec 2007
    hey bro, eto ang gawin mo. before starting the engine (sa umaga) make sure na filled up completely ng Coolant or Tubig ang Radiator pati ang Coolant Resvoir. then, hayaan mo lang na naka tanggal ang Radiator Cap, tapos i-start mo ang makina. then i-on mo ang Heater (kung meron) in full blast.
    now, hayaan mo lang tumakbo ang makina hanggang sa mag warm up. and pag may bubbles pa, ibig sabihin may hangin pa sa loob ng Cooling System ng kotse. so paandarin lang ang makina (idle for about 8-10 mins. wag mo lang i-rev) then lagyan mo pa ng tubig pag nabawasan.
    so pag medyo mukhang stable na ang tupig sa Radiator (makikita mo naman yun eh, specially pag nag fo-flow ang tubig (sideways.. hindi palabas at pataas!) at pag wala ng bubbles, pwede mo ng ibalik ang radiator cap.
    but, kung malakas pa din bumulwak ang tubig.. then you probably have a slow leak in the Cooling system (small leak on the Head Gasket or a crack in the Cylinder Head).
    anywayz, hopefully may natirang hangin lang sa loob ng Cooling System mo na pwede naman i-purge out. so try to do the procedures above then tell us what happend once you have done it.
    aite, peace.
    Sorry sa kinalabasan ng first item sa post na to. Nagmamadali kasi ako dahil may scheduled power interruption nung nag post ako, ngayon ko lang nakita ng kinalabasan. Sorry uli.
    KBR, thanks for the input. Try ko yung sinabi mo bukas. Pang 2nd week ko na itong gamit, pero may kakaunting bubbles pa rin akong nakita. Hopefully hindi sana ito major problem.
    thanks again.
    BRO pwede mo naman edit yung first post mo para hindi mahirap basahin, alisin yung mga di naman kailangan doon.
Air bubbles sa radiator pag umaandar
