Page 9 of 15 FirstFirst ... 5678910111213 ... LastLast
Results 81 to 90 of 141
    #81
    ssaloon,
    try mo un mga moster flow.. alam ko mas mura..
    mas mabilis pa linisin.. hehehehe
    #82
    san pwede magtanong ng mga monster flow? magkano naman? kamusta performance? may kasama bang tubo yan? dami ko bang tanong? :D
    #83
    hinde naman.hehehe
    parang sponge kasi un eh. so pag madumi na.. tubig.. taran.. ok nanaman.hehehe
    2 thou ata.. not so sure ah..
    nakita ko dati sa speedwerks...hehehe
    dun mo na lang tanung.. hidne ko sure mga kasma eh..
    sabihin mo nirefer ka ni odell.. un naka lancer na pearl dati.. dun kasi ako lagi pahugas dati.hehehe
    #84
    may contact number ka pare?
    Aug 2003
    #85
    Pasensya na po, may ignoranteng tanong lang po ako. Ang ibig po bang sabihin pag naglagay ng drop-in filter ay papalitan yung stock filter ng kasing korte at laki na filter pero yung same box na pinaglalagyan pa rin ang gagamitin? :D
    #86
    alam ko hindi na gagamitin yung OEM air filter box.
    May 2004
    #87
    guys, i have a k&n filter and it's due for cleaning. k&n recommends that i use the filter cleaner and recharger to clean it because the recharger traps the dirt after cleaning it. is it true that i'll destroy the filter element if i use soap and water to clean it? do you guys know any other way/means to clean this without buying k&n's filter cleaner and recharger? thanks!
    Nov 2003
    #88
    sayang k&n mo if you don't use the cleaner. it's cheap and it will last a couple of years naman (maybe 5-6 cleanings) so it's worth it to purchase.
  9. #89
    I clean my K&N using high pressure air and water lang eh
    #90
    May K&N's kaya dito for Subaru's (Legacy 95-96)? ;)
Aftermarket Air Filters (Simota, K&N)
