Page 13 of 15 FirstFirst ... 39101112131415 LastLast
Results 121 to 130 of 141
    Aug 2007
    #121
    mayroon po bang k&n cone type para sa 2000 gli manual? kung meron man san meron at mga magkano yung kumpleto na sana, tubo, filter at kung may kulang pa padagdag nalng. thank you.
    Sep 2006
    #122
    Got mine, K&N 4,500 + 1000 Tube including labor. Kung carb type yung makina mo like mine, you need the adaptor. worth 2000 market value pero if your lucky you could get it at 1k.
    I suggest you also get a breather kahit SIMOTA worth 250. 2200 naman pag K&N.
    Quote Originally Posted by vanjo View Post
    Aug 2007
    #123
    Hi mga tol! meron ba kayong masusuggest na air filter para sa mitsubishi lancer el 94? thanks!
    Nov 2006
    #124
    guys how about for revo gas? may advantage kya pag nagpalit ako to cone type fliter? meron n bang ngka try,,if ever what model ng filter?
    malamat in advance
    #125
    and is it true that in the long run switching to after market cone type filters would be comparatively less expensive than changing elements every now and then?
    That depends how much your air filter is. Pajero replacement air filters used to be around Php200.00.
    How many replacement filters would you need to recoup the cost of the K&N [and its cleaning kit]?
    If you're after penny pinching, I don't really think replacement filters are it. They're still a performance/cosmetic item above anything else.
    #126
    saan nakakabili ng urethane simota air filters?
    Nov 2007
    #127
    pag naglagay kaya ako sa a32 ng after market airfilter may difference kaya? sabi nila wala daw e
    #128
    Blitz with flange and MAF you want?
    Central Diesel 4113711 to 13
    Mar 2007
    #129
    mga tol saan ba makabili ng drop in na air filter? yung square ang shape. for honda city 2006 sana
    Oct 2016
    #130
    hi guys. Magkakaroon ba ng additional power kung air filter lang mismo paplitan ko pero gamit ko pa rin ang stock air filter box ( yung kulay itim)? Change ko sana to K&N or any performance type filters ( any suggestions ba?)
    Auto ko ay 1997 Mitsubishi Lancer 1.6 GSR MT
    Parang ayoko kasi i-modify to S.R.I. dahil may nabasa ako at sabi ng ibang may auto wala effect dahil nahihigop din yung init ng makina.
    TIA guys
Aftermarket Air Filters (Simota, K&N)
