Results 91 to 100 of 141
- May 2004
- 20
September 23rd, 2004 08:27 AM #93
anyone here tried K&N open type on diesel engines? was wondering if it will add up noise (specifically isuzu engine)...although isuzu's are noisy by nature...
September 23rd, 2004 10:20 AM #94
nakabili ako ng k*n for 4200 hindi siya regular type shape filter. mas mahaba yung sa akin. hindi pa kasama tube nun. dati naka simota rin ako and yep, sobra laki ng difference compare to simota. matic yung akin. go for k*n or aem :D
- Dec 2004
- 3
January 26th, 2005 09:27 PM #95Hello!
Anybody out here who has changed their Toyota Altis stock air filters to Shimota open type air filter? Also, do i need a breather if ever I had installed the Shimota air filter? What is the breather's purpose?
Thank you!
September 12th, 2006 10:52 PM #96
Guys buhayin ko lang to..
Does anybody here use SIMOTA AIRFILTERS
I found this in a website..
SIMOTA Urethane filter and breather (blue element) -for JAZZ
Is this a good buy?
What changes will i experience?
September 22nd, 2006 12:46 PM #97
i used a drop-in k&n filter for my jazz. became much much more responsive off the line and pulled better sa higher RPM range.
September 22nd, 2006 05:51 PM #98
using a drop-in HKS for my camry. aside from additional responsiveness, the sound is great!
same thing with my friend's camry. the K&N drop in isn't as noisy as the HKS tho.
- Jan 2007
- 12
February 18th, 2007 09:47 PM #99*[SIZE=5]supierreman[SIZE=2] yung address ng motorco 11 pagataan st. manresa QC? FusionR and motorco mag sister company? 2 lang dealer ng K&N na check ko sa site ung isa Filtech indust. sa mandaluyong malayo e2 s akin. hope n ma2lungan mo ko[/SIZE][/SIZE]
- Apr 2006
- 23
February 18th, 2007 10:44 PM #100talaga kahit drop-in filter lang ipalit may difference na?
medyo alanganin kasi ako mag open type kasi experience ko dati dun humina hatak ko sa low rpm pag mainit.. puro hot air kasi nahihigop..
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
