Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    Dec 2008
    #21
    Quote Originally Posted by [archie] View Post
    Sir when you mean popcorn, parang kumukulong radiator nasa isip ko. Or parang lakatak na tunog? Try to start from cold ng walang radiator cap, kung umangat tubig, may singaw na.
    sir, if ever umangat ang tubing, kelangan naba irepair rediator?
    #22
    Not the radiator, head na ang problem. May singaw na.
    Jul 2011
    #23
    Sir archie, baka ma-mislead si pepito7, i-clear natin.
    During cold start, pag naka-idle na, okei lang na umangat angat yung tubig sa bibig ng radiator mo. why? If you have an existing radiator thermostat, it blocks most water flow sa engine mo, eh ang water pump, walang pahinga, so it still pump water and fills your radiator back with water, so ang tendecy, aangat lang ng aangat yung tubig, not until na maabot n ng operating temp ang engine, bubukas na yung rad thermostat, dun lang magiging dirediretso yung flow.
    Ang mas abangan mo is yung "bubbles", if may bula bula na umaangat sa radiator, yung ang isang sign na may tama na ang head gasket.
    Jul 2011
    #24
    Quote Originally Posted by pepito7 View Post
    Sir 7138, suggestion ng mekaniko is to top up. kaso di ko pa nagawa. may idea ka how much sa shell station mag pa top up ng engine oil? or change oil?
    not sure sa price ng engine oil sir,
    bili ka nalang sir ng engine oil kahit 1 liter sa suking bilihan mo ng oil, as much as possible din, same oil na currently nasa engine mo na,
    kaya naman DIY yan sir, top up ng onte then check dipstick, ulit ultin mo lang hanggang malapit na sa full or full n ang level. then observe.
    Dec 2008
    #25
    Quote Originally Posted by 7138 View Post
    Thanks sa reply nyo sirs.. as per checking this morning di naman bumubula water sa rad. one more thing, san ko ba makita young head gasket? hehe sensya na ropor ako pagdating sa car..
    thnaks ulit.
    #26
    Sorry wrong term umangat yung water. More of fountain pala dapat sinabi ko. My bad.
90 corolla GL overheating problem needs help
