Usual things to be changed (this can vary but its a safe bet):
- oil/oil filter
- spark plugs
- air filter
- fuel filter
- gear oil/ATF
- differential oil (if any)
- PS fluid
- brake fluid
- t-belt (if any)
- water pump
- valve tappet clearances are checked and adjusted (if needed or if the engine doesnt have auto adjust valve tappets)
- Clean the brakes
- Check the suspension/underchassis
- Check the belts and hoses
- Replace your radiator cap (if this is already a few years old)
If you buy the parts, a Goodyear Servitek or shops like Speedyfix can do the job. Most of my 80,000km service was done at my suking mekaniko and Motech.
