Results 1 to 10 of 10
- Nov 2009
- 21
April 8th, 2010 11:53 AM #1Hi! I have a corolla 91 witha 2e engine and I can only accelerate up to 60kph. After nun may vibrations na and halos di na bumibilis pa. I need help finding out what the problem is. Bagong overhaul yung makina late last year pero ngayon ko lang napansin na ganito ang problema.
April 8th, 2010 12:10 PM #2
- Nov 2009
- 21
April 8th, 2010 12:23 PM #3Yes sir, bagong adjust din po ang timing and di ko naman naiiwan ang sasakyan. Di ko lang napansin na di na pala kaya umakyat ng 60kph. Napacheck ko na din po clutch and wala naman daw problema. Bago din po battery ko. Di ko lang po alam kung related ito pero yung check oil lamp ay matagal bago mawala. Ok naman oil level, twice pinalitan yung oil sensor daw and yung oil pump natingnan na din
- Apr 2010
- 8
April 8th, 2010 09:27 PM #5
- Nov 2009
- 21
April 9th, 2010 01:46 PM #6Sige po at ipacheck ko sa mekaniko. Update ko na lang kayo kung ano man makita. Salamat!
- Nov 2009
- 21
April 21st, 2010 10:28 AM #7Update lang po sa kwento ng kotse ko. Binuksan na ng mekaniko and madami na daw tama ung crankshaft, bore and piston. Di daw nagcirculate nag oil. Kakapagawa ko pa lang naman nun. Patay na makina ko. May bibili pa kaya ng kotse na ganito? Walang makina.
April 27th, 2010 07:02 PM #9
palit ka bro change engine 4age o kaya agze then punta ka sa crame at lto pa change engine number mo sa C.R
April 27th, 2010 11:36 PM #10
Malaki rin magagastos mo pag pinaayos mo makina mo parang bumili ka na rin ng surplus na makina.
Traffic!
