Results 11 to 16 of 16
- Nov 2006
- 45
December 4th, 2012 05:56 PM #11
- Nov 2006
- 45
December 4th, 2012 06:05 PM #12
- Nov 2006
- 45
December 4th, 2012 06:23 PM #13
sir i tried this procedure on my 4k engine yesterday... bakit po ayw umilaw ng test light ko.. naka ON ang power, peo ayw pa rin umilaw kahit anong ikot ko sa pulley ng crankshaft.. magkaiba ba wiring sa VW sa video at sa 4k engine? kasi sa video naka attached yung wire ng test light nya sa negative nung ano ba tawag don igniter? tama po ba? tapos nakaground naman sa body / engine yung tip ng tester, peo wala nangyari po... ikot ko na pulley wala nangyari, ikot ko yung advancer, paulit-ulit peo wala tlga umilaw eh.
ask ko na rin po... pag advance timing ba 4k engine ba eclockwise ang ikot ng advancer or counterclockwise?
December 4th, 2012 07:39 PM #14
kaya pa pababaan yan hanggang 80. hanapin mo yong A/F screw. bali adjustment lang ng hangin at fuel ang kailangan para makatakbo ng maayos. normal lang pag sakal na alalay sa selindayor para di mamatay. kapusin talaga ng fuel pag start up, kaya alalayan mo ang makina. regarding timing light, may instruction naman sa manual nyan. kung wala, google mo. sa uno mo dapat ilagay ang malaking clip ng timing light. hope this helps.
December 4th, 2012 07:40 PM #15
How to Set the Timing on an Engine By Use of a Timing Light | eHow.com
hope this will help.
- Nov 2006
- 45
December 5th, 2012 06:48 PM #16thanks sa link sir... yes i also watched that video using a timing light and unfortunately i dont have one, .. so i just prefer the vid posted above. I think i know whats the problem why it wont light on my tester screw driver, i cant find the breaker point or they call it contact point, it was already converted to electronic igniter so i dont have the contact point anymore... :D .. they said it is better than the contact point thing well in terms of durability.
so sad im too excited when i got my tester screw driver from a store to perform the procedure..
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
