Results 1 to 3 of 3
    mga sir need some advice po.ang problem ko po kasi may leak ng langis lumalabas siya sa dun sa valve cover yata ang tawag dun basta yun yung takip s ibabaw ng makina bagong palit na po ung rubber tapos may silicon n din para din pro still may langis pa din n lumalabas.base po sa observation ko parang sobrang lakas ng pressure ng hangin sa loob ng makita tapos naghahanap siya ng butas na malalabasan, kasi nung kapapatay lang ng makina tapos binuksan ung turnilyo nung valve cover sumirit yung hangin.saan po kaya yung posibleng may bara kaya di maganda yung airflow?salamat po....
    May 2007
    Quote Originally Posted by skipper529 View Post
    Changed your PCV valve. PCV valve you can usually find a location on the vacuum diagram under the hood. Its a black plastic or gray on top of your valve cover w/ vacuum hose.
    Oct 2008
    agree.. check the pcv valve or positive crankase ventilation valve and check mo na din yung system nya.. check mo na din yung aircleaner mo tignan mo kung may oil.. it means nag back flow yung oil nya.. may pcv filter naman yan.. pag may oil sa air cleaner. check mo na yung pcv valve.. dapat nag rarattle sya, pag hinde barado na sya.. tnx
2e engine leak
