Results 11 to 19 of 19
December 12th, 2012 05:05 PM #11
I suggest you have it checked immedietly. Traffic situations right now in the metro are horrible to say the least. You might be stuck on the side of the road. If you can't, then I suggest you defer from using added electrical load during night driving, as this is the time that your electrical system consumes power a lot (if all are turned on).
So turn off that radio muna, if hindi naman ganoon kainit, turn off the AC and open the windows halfway (do not open totally for security reasons).
- Mar 2009
- 823
December 12th, 2012 05:37 PM #12
Tsikot Member Rank 4
- 2,716
December 12th, 2012 11:06 PM #13mura lang yung digital multitester sa cdr-king ... malaking tulong sa pag-testing ng electricals sa oto
- Aug 2011
- 6
December 30th, 2012 05:33 PM #14Hi again, the same problem persists and even got worse. I had my alternator and clutch master kit replaced recently. Ganon pa din problem, the rpm is fluctuating. Pag mag menor ka, bumabagsak yun rpm tapos namamatay makina. Binalik ko sa gumawa ng alternator, he checked the voltage reading, tama naman daw. Hindi daw sa alternator prob. He then asked us to go to this other mechanic para paadjust yun idle. The thing is, malakas naman sa gas tapos after a few hours, ganon na naman, rpm fluctuates and engine dies pag mag menor na. Itutulak na para umandar.
What else could be wrong with my car??
San ko ba maganda patignan para macheck na lahat ng kailangan macheck?
Any suggestions? I'm from muntinlupa.
Thanks in advance!
- Jun 2008
- 1,741
December 30th, 2012 06:45 PM #15I suggest have your car undergo diagnostic scan test (if that is equiped with obd port ).
- Jul 2011
- 1,711
December 31st, 2012 07:10 AM #16
From the negative terminal of your battery check mo kung saan nakakabit ung black na cable (ground), most likely isang wire lang yan at nakakabit sa body ng car mo. Since ok naman ang battery mo at alternator baka you need to add additional grounding kit, mura lang naman din ito at better magpatakbo ka ng isang wire (from the negative terminal of the battery) na naka tap sa engine.
What is a grounding kit and how does it benefit someone's car : G35 and G37 General Discussions
December 31st, 2012 12:39 PM #17
my two cents worth...start with the basic..try mo rin pa-check yun fuse (10Amps) usually for the motor...
- Aug 2011
- 6
January 20th, 2013 10:20 PM #18Update:
As of Jan 11, my car is running ok. Bought a new motolite enduro battery and finally had the alternator rechecked. So ok na sya sa ngayon. The only problem remaining is the stepper motor/ servo. According to the mechanic that was recommended to me by a friend, kailangan ko na daw magpalit ng servo motor.
I'm not exactly sure if I understood everything he explained basta I need to have it replaced because mine is already busted that's why nagfa-fluctuate daw yun kuryente.
Tama ba pagkaintindi ko?
He said I need to set aside 10-12k for a new one.
Does anyone here know what kind.of servo motor a nissan altima 1994, manual transmission?
I saw a someone in sulit selling a second hand servo for nissan.altima 1996, automatic transmission. It's an SR20DE daw. Is this the same kaya?
Please, i need your suggestions/comments
- Jul 2010
- 570
January 21st, 2013 09:36 AM #19Baka IACV or Idle Air Control Valve iyan. Mahal pala 12K. Hwag muna bili ng bili ng parts.Try mo muna palinis yun IACV dahil luma na kotse. Hangin kasi dumadaan diyan at baka barado na.
Pwede rin loose lang connector ng stepper motor.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
