View Poll Results: What is the Longest Life of your Battery?
- Voters
- 88. You may not vote on this poll
less than 2 yrs
4 4.55% -
2 years
20 22.73% -
3 years
20 22.73% -
4 years
23 26.14% -
5 yrs and over
21 23.86%
Results 461 to 470 of 531
- Jan 2008
- 4,726
June 28th, 2022 05:38 PM #461I have that electronic batt tester.. works good.. you need to choose your batt type and test method..
Can test crank power din..
Sa experience ko with motolite.. mataas pa lahat water level pero weak na talaga.. then when measured, high internal resistance na
- Oct 2021
- 32
August 10th, 2022 01:37 AM #462My Mazda CX-30 when I drove it 2 weeks ago it has around 14v when I checked.
Earlier before driving from work I noticed mejo matagal yung engine start from the usual. When I check the voltage it only has around 12.2v. Pero nung nakauwi na ako nasa 13v na ulit.
Should I be worried? Sakto parating na yung CTEK CT5 I ordered this 8.8.
Btw I only use this cigar port device to check the battery voltage. Not sure if accurate sya.
Sent from my HD1900 using Tsikot Forums mobile app
August 10th, 2022 09:45 AM #464
- Jan 2008
- 4,726
August 10th, 2022 10:45 AM #465Remove sticker on top of battery to access screw caps.. no need to reinstall the sticker
- 52,731
August 10th, 2022 10:56 AM #466yespo.
most of these maintenance-less batteries have a warranty sticker covering the plastic plate that covers the filler holes.
if one opens the battery, the warranty sticker is torn, voiding any remaining warranty. the plastic plate can then be prised open with one's fingers, or with a flat-blade screwdriver.
if one wants to preserve warranty,
one must wait until the warranty expires, then tear it off the very next day and inspect the water levels.
- 52,731
August 10th, 2022 11:08 AM #468
- Jul 2009
- 2,618
August 10th, 2022 11:57 AM #469
August 10th, 2022 12:01 PM #470
battery acid is for brand new batteries na wala pa "tubig"
the battery shop fills it when you buy a battery
after using the battery for months/years, pag bumaba ang level, you use distilled water pandagdag
battery water that you buy in shops is distilled water
sa pagkaalam ko hindi battery acid ang pandagdag
it's only for brand new batteriesLast edited by uls; August 10th, 2022 at 12:05 PM.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
