Results 11 to 15 of 15
October 4th, 2012 11:07 AM #11
before you embark or go deeper into the jungle on a wild goose chase, make sure that your ammeter is not miscalilbrated, broken or is not properly connected. try measuring the current with a more precise instrument, perhaps a digital multimeter with inductive pickup or a clamp on inductive ammeter. the generic ammeters like rox, lucas, autometer and other brands gets stuck or sluggish over time. heat, sunlight and age makes the movement of the needle difficult. if the ammeter is connected next to a magnet, the magnetic field interferes with the true indication of current. verify the current with another known good working ammeter first.
- Jul 2003
- 573
October 5th, 2012 06:40 PM #13
October 5th, 2012 07:24 PM #14
check muna alternator, baka mahina na ang charging.. probably due to carbon going bad..
October 8th, 2012 09:04 PM #15
sir ok naman yung charging ng alternator niya, napa-check ko na po with multi-tester sa aking trusted auto electrician, while at idle, normal naman..above zero range yung ammeter ko, maganda pa daw ang charging...kapag full charge na yung battery, stable at zero na siya..kayang-kaya niya yung mga electrical load like stereo, parklight, interior lights..pero yung headlight, dun lang talaga nag-ffluctuate yung ammeter reading, goes slightly below zero(going negative na)..sabi pa-check ko daw wiring nung headlight baka daw may loose connection at additional nga pala, yung headlights swith ko rin nga po pala is wala sa ayos, pagnag-pass by ako di nailaw, pagnaswitch ako into dim, wala pero paghigh meron..hinala doon rin po ang cause nun, wala sa tamang arrange yung headlight switches, btw, nasabi din sakin nung dating may-ari na napa-rewire niya na yung OTJ 5 mos. ago,
