Results 331 to 340 of 381
- Nov 2009
- 3,484
July 13th, 2020 01:11 PM #331I have four of those smart chargers. In the house, in the flat, in the car, at the office, in the farm(dumb charger). Then 3 of those battery tester, 2 VRLA 50aH battery used to be for solar use, then 3 laser printers, 2 flatbed scanners, 1 a3 scanner..hehe. Redundancy indeed makes more options in life, easier, and worry-free. Don't wonder why other have many gf's
July 13th, 2020 01:29 PM #332
- 52,724
July 13th, 2020 01:43 PM #333
July 13th, 2020 01:46 PM #334
It's only to prevent arcing on the battery terminals, which is a precaution against igniting any hydrogen gas at the vicinity of the battery caps and/or vents.
Most smart chargers are "OFF" by default and will only turn on manually via a switch/button or via logic after it has detected a battery present. This prevents arcing and so, clamping directly on the battery terminal posts is acceptable.
If you're using dumb chargers, connect the battery clamps first before turning on the charger. When finished, turn off the charger first before removing the battery clamps. To forego that sequence, mount the negative clamp on the chassis or engine so any arcing won't be near a hydrogen gas source.
July 14th, 2020 09:01 AM #335
July 14th, 2020 10:04 AM #336
July 14th, 2020 10:19 AM #337
bro ganito setup ko sa akin, rekta smart charger
tapos yung clamp, may sarili connector din [emoji28]
Check out {Giving}New Quick Disconnect Wire Harness 2 Pin SAE DC Connector Cable Cord 14AWG 1FT 30cm at 50% off! ₱116 only. Get it on Shopee now! https://shopee.ph/product/170358360/...631?smtt=0.0.9
Check out 12V Terminal To SAE Quick Disconnect Cable Motorcycle Battery Output Connector at 40% off! ₱120 only. Get it on Shopee now! https://shopee.ph/product/132041196/...443?smtt=0.0.9
Sent from my RMX2020 using Tapatalk
- Sep 2006
- 2,746
July 14th, 2020 10:42 AM #338
July 14th, 2020 11:04 AM #339
I don't quite agree with that.
There are inherent risks when charging FLA batteries that has a lot to do with hydrogen gasses and arcing, which I already covered a few posts back. But as far as other electrical/electronic devices, the order in which a device is connected and powered depends on the specific equipment.
As per your example, laptops can be powered up before (ie. on-battery) or after the AC power is applied... it won't matter.
July 14th, 2020 11:14 AM #340
What vehicle and what's your budget?
