Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
    #31
    Merong benta sa ACE Megamall and True Value Rockwell na portable car battery booster. Don't know if meron sa ibang branches nila. Estimate size is like 2x3x0.5". Claims it can start a car with fully drained battery. Haven't tried, so can't confirm if it will perform properly.
    #32
    Quote Originally Posted by machine.pistol View Post
    I also have this for my RC planes. But isn't it dangerous to be lugging this around inside your car, which is parked in the extreme heat? Ok lang ba?
    it says, only 2.2 amperes! can this really start an automobile engine?
    Jun 2006
    #33
    Thats capacity, some lipos are capable up to 60c. It started my vvti innova and vios. Parasitic drain of my amps tends to drain my batts if i dont use the car for more than a week.
    #34
    Quote Originally Posted by shibby75 View Post
    errr... i'm not up to the lingo.. what's "60c" ?
    Aug 2012
    #35
    *shibby75: magkano bro yang ganyang RC battery na gamit mo?
    Aug 2012
    #36
    Yes, assuming it is true rated and capable of high discharge output..
    Capacity = 2.2 Ah
    = 2.2 A for 60 min
    = 132 A for 1 min
    = 264 A for 30 sec (enough to start most engines)
    Capacity = 2.2 Ah
    = 2.2 A for 60 min
    = 132 A for 1 min
    Aug 2014
    #37
    Quote Originally Posted by red_one View Post
    Capacity = 2.2 Ah
    = 2.2 A for 60 min
    = 132 A for 1 min
    SO, the outlast motorcycle battery, should be enough.
    12N10-3B
    12V
    12 AH *10HOUR
    1.0 Current of 1Amp
    980.00 Pesos retail price
    Correct my if my computation is wrong
    120A per Hour
    720 Amp per minute
    So motorcycle battery should work.
    Capacity = 2.2 Ah
    = 2.2 A for 60 min
    = 132 A for 1 min
    12N10-3B
    12V
    12 AH *10HOUR
    1.0 Current of 1Amp
    120A per Hour
    720 Amp per minute
    Aug 2012
    #38
    Quote Originally Posted by aioshin View Post
    12N10-3B
    12V
    12 AH *10HOUR
    1.0 Current of 1Amp
    120A per Hour
    720 Amp per minute
    If capable of high discharge output, then it will work. Better ask Outlast store what is the maximum (peak) current output of that model.
    12N10-3B
    12V
    12 AH *10HOUR
    1.0 Current of 1Amp
    120A per Hour
    720 Amp per minute
    Oct 2013
    #39
    Sabi ng cellphone batt lang katapat nyan.
    May 2009
    #40
    eto naisip kong alternative:
    TWIN BATTERY system
    - connected in parallel pa rin (syempre kung 12 V)
    - tapos hindi sabay matapos ang expected lifespan ng 2 batteries (which is 2 years minimum). say yung battery 1 is expected to die this month. tapos yung battery 2 is 2 years away pa before replacement. that way hindi mabigat sa bulsa ang palit ng battery.
    - you can do it with smaller 2 sm batteries. not 3 sm.
    - mas nakakarelax pa siguro sa battery during starting dahil dalawa silang magtutulungang magstart ng makina
    - yung cheapest battery (Pesos per month basis) na low maintenance ang kunin mo
    provided may space pa for the extra battery.
    well, sasabihin ng iba x2 ang costs pero ang hinihingi kasi ng TS e reliability (on starting).
    regarding sa cons netong system na ito e isipin nyo na lang kung ano iyon. wala ako maisip bukod sa cost e.
Smallest Emergency Battery that can be use to start the our car
