Results 31 to 40 of 45
April 11th, 2015 04:11 PM #31
Merong benta sa ACE Megamall and True Value Rockwell na portable car battery booster. Don't know if meron sa ibang branches nila. Estimate size is like 2x3x0.5". Claims it can start a car with fully drained battery. Haven't tried, so can't confirm if it will perform properly.
- 52,700
April 11th, 2015 04:16 PM #32
- Jun 2006
- 1,139
April 11th, 2015 06:24 PM #33Thats capacity, some lipos are capable up to 60c. It started my vvti innova and vios. Parasitic drain of my amps tends to drain my batts if i dont use the car for more than a week.
- 52,700
April 11th, 2015 07:10 PM #34
- Aug 2012
- 2,767
- Aug 2012
- 2,767
April 11th, 2015 09:01 PM #36Yes, assuming it is true rated and capable of high discharge output..
Capacity = 2.2 Ah
= 2.2 A for 60 min
= 132 A for 1 min
= 264 A for 30 sec (enough to start most engines)
Capacity = 2.2 Ah
= 2.2 A for 60 min
= 132 A for 1 min
- Aug 2014
- 391
April 11th, 2015 09:16 PM #37SO, the outlast motorcycle battery, should be enough.
12N10-3B
12V
12 AH *10HOUR
1.0 Current of 1Amp
980.00 Pesos retail price
Correct my if my computation is wrong
120A per Hour
720 Amp per minute
So motorcycle battery should work.
12N10-3B
12V
12 AH *10HOUR
1.0 Current of 1Amp
120A per Hour
720 Amp per minute
- Aug 2012
- 2,767
April 11th, 2015 09:42 PM #38If capable of high discharge output, then it will work. Better ask Outlast store what is the maximum (peak) current output of that model.
- Oct 2013
- 1,181
April 12th, 2015 09:18 AM #40
eto naisip kong alternative:
TWIN BATTERY system
- connected in parallel pa rin (syempre kung 12 V)
- tapos hindi sabay matapos ang expected lifespan ng 2 batteries (which is 2 years minimum). say yung battery 1 is expected to die this month. tapos yung battery 2 is 2 years away pa before replacement. that way hindi mabigat sa bulsa ang palit ng battery.
- you can do it with smaller 2 sm batteries. not 3 sm.
- mas nakakarelax pa siguro sa battery during starting dahil dalawa silang magtutulungang magstart ng makina
- yung cheapest battery (Pesos per month basis) na low maintenance ang kunin mo
provided may space pa for the extra battery.
well, sasabihin ng iba x2 ang costs pero ang hinihingi kasi ng TS e reliability (on starting).
regarding sa cons netong system na ito e isipin nyo na lang kung ano iyon. wala ako maisip bukod sa cost e.
