Results 11 to 14 of 14
- May 2011
- 481
August 14th, 2017 06:06 AM #11
Similar to doctors, Auto service technicians use a DSO (digital storage oscilloscope) instead of an EKG or electro cardio graph. If you hook up the signal lead to terminal 16 of the DLC or diagnostic link connector and the ground lead to terminal 4 you can observe the behavior of the system voltage. If you try to disconnect the sinal wire from terminal 16 ( which I strongly discourage) you will see a voltage spike sometimes reaching to a 100 volts. This is what you don't need, similar to applying AED to a person who does not need it
October 10th, 2017 12:46 PM #12
Sorry for the late reply.. Okay na yung auto.. Di nakakabit maigi yung battery.. Nothing more nothing less.. Maluwag siguro yung paglagay sa CASA after ng PMS.. Hinigpitan lang.. Di na nagloko after..
October 10th, 2017 08:16 PM #13
^Spark plugs need stable electric supply
Sent from my GT-P3110 using Tsikot Forums mobile app
- Feb 2017
- 5
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
