Results 11 to 15 of 15
- Oct 2015
- 922
February 23rd, 2016 09:52 AM #11^ agree..
Nung around 90s e 0.50 cent lang ata yan. Baka ngayon 1 peso na..
- 52,731
February 23rd, 2016 01:03 PM #12i can't seem to access the pictures, so i don't know what these items are.
but if they are what i think they are, the color rings around them and the size, are the code to their resistance value and their power rating.
any repairman worth his soldering gun, should decode these on sight.
btw... wala ba ito sa owner's manual?Last edited by dr. d; February 23rd, 2016 at 01:15 PM.
February 23rd, 2016 02:30 PM #13
I don't think it is in the owner's manual.
The physical size of the resistor determines its power rating:
1/4 watt - smallest
1/2 watt - smaller
1 watt - small
5-watt - large
10-watt - large 2x
By the way, if you have a clear colored picture of the actual resistors to be replaced, post here and we will try to decode it so you will have an idea of its values before going to the store.
- Oct 2004
- 278
February 23rd, 2016 08:01 PM #14Baka resistor block for low impedance fuel injectors yan...
Depending on car, usually nasa 10R (10 Ohms) nasa mga 15-20Watts siguro each (enclosed sa ceramic case).
BANNED BANNED BANNED
- Jul 2013
- 421
February 27th, 2016 08:31 PM #15usually 1 - 10 ohms fusible resistor rated * 2A. this is used in cfl and electric fans. hindi critical ito just as long as the amperage is not exceeded. temporarily, bili ka ng 2A fuse together with fuse holder. ang paginstall, bahala na ang car electrician mo.
