Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Aug 2008
    aga_cruz /esnie.com - re: redondo
    kapag idle for a few days at start ko, nde lang click meron din redondo pero pahina ng pahina habang inuulit ko itry istart
    additional info nga pala, kapag iistart ko sya kailangan ko pa apakan ang gas at least once bago ko start ang ignition kse pag nde inapakan nde magstart (kapag malamig ang engine). kapag mainit ang engine, no need apakan ang gas.
    bambino - sang wiring kaya po ang problema, sa alternator or battery?
    current draw means meron constant draw ang battery mo kahit OFF ang ignition
    magagawa yan ng auto electrician
    isolation( technical term ) ang gagawin diyan para ma pinpoint ang root cause ng trouble
    ipagawa mo na lang sa auto electrician para mawala na ang sakit ng ulo
    jumpstart lng
    Quote Originally Posted by starfire View Post
    Sis, first question ko. Are you first owner or second / third owner na. Meaning, did you buuy the car brand new o second hand na.
    Second question: Kung brand new when you bought it, did you have any accessories ( Stereos, Fog lamps, back up lamps, alarms...etc) attached that aare not standard? If Second hand, did the car come accessorized.
    In most cases, any accessory attached to the car, if not properly connected, will become a drainer of your batteries.
    Tama si bambino, just bring your car to a qualified auto electrician, HUWAG LANG BASTA ELECTRICIAN, HA! or bring it sa casa. Mahal ang singil but they know the car very well.
    Pagdating sa need to step on the gas pedal once to start, tune -up po yan. Also, need to clean your fuel system, easpecially the fuel filter. malamang, sa tagal na ng kotse mo ay di pa napalitan yan. Kung carb system, have the carb overhauled na rin.
    At most, your engine may need de-carbonization or top over haul.
    Again, mas mainam, dalhin mo na lang sa casa.
problem starting car
