Results 31 to 40 of 80
October 22nd, 2009 10:56 PM #31
Maraming salamat, sir howee. Medyo out of the way sa akin ang Fairview kasi pa-Maynila ang pasok ko. Try ko muna yung Wizzard, kung palpak, subukan ko recommended shop mo.
Sir anthon05, salamat sa contact number. Tawagan ko sila maybe this weekend. I'll post my feedback and the cost of repair if matuloy ako.
- Apr 2009
- 544
October 26th, 2009 11:44 AM #32galing lang ako sa wizzard last saturday, pinaayos ko yung power lock ko,
dami nagpapagawa ngayon doon mga lumubog na sasakyan sa baha.
buti may tao sila para sa mga minor repair kaya sandali lang naayos na
pinalitan nila actuator. gastos ko lang pati labor na is 500+.
- Nov 2009
- 4
November 25th, 2009 02:40 PM #33Hi, where's Motech in Fairview? san banda yun? need help for my power windows, nag stuck up kasi after ng flood
- Sep 2009
- 12
November 30th, 2009 02:45 PM #34mga tol, power window at power lock lang ba ang na rerepair sa wizzard? may ibang concern pa kasi ako.
- Apr 2009
- 544
December 1st, 2009 07:25 PM #35sa wizzard hindi lang power window and locks.. starter/alternator repair etc,,.
i'm sure lang sa mechanical.
- Aug 2009
- 34
May 25th, 2010 07:38 PM #36Smoked2020, na try ko na din gumamit ng silicon spray, bumilis naman kahit papano pero hindi sya ganun kabilis like nung brand new pa sya. So bumili nalang ako ng bago sa may taft avenue, sa mga auto supply dun. 1,600 brand new. By the way, pano ba gumawa yung wizzards kapag totally sira na yung motor ng power window para if ever na masira yung power window ko ulit dun ko nalang pagawa.
September 29th, 2010 11:36 AM #37
thanks sir buknoy! sinubukan ko si zaldy.. satisfied customer here! repost ko lang yung post ko from HCP:
Thank God! ayos na power windows (driver side & rear left), plus yung door lock ko. i opted to brought it sa expert na lang, mukha kasing di ko kakayanin pag-DIY. true enough, di nga. I spent P1K sa lahat, pure labor, walang parts na pinalitan. lahat overhauled, working pa naman kasi. dito sa Zaldy's Trading ko dinala.. sinubukan ko lang base kasi dito sa nabasa ko from tsikot.com (sorry, as of now down ata server ng tsikot, kaya di ko malink, copy-paste ko na lang yung comment, pinrint ko kasi yung address):
Power window repair...
I have my rear door power lock and driver side window mechanism repaired this morning. The left side rear door lock is no longer working in auto power mode and have to engage/disengage it manually. The driver side window is out of alignment which damage the rubber on the window side and most cases the window is very difficult to open/close as the glass hit the rubber.
I brought it this morning (7am) at Zaldy's Trading located at the corner of apolinario st and SLEX extension near buendia. They found my door lock motor busted and they replaced it with exactly the same surplus unit. The window mechanism was aligned by balancing the glass riser. By 8am all is done and I paid 1,400. I recommend this shop as they knew what they are doing and understand the value of time as they assigned 2 of their technician to work on my rig. They gave me 3mos warranty and promise that they will not charge me should i have problem on their work during its warranty period. The shop specializes on power lock, power window, wiper and door lock for all kinds of car. Tel # 8439459, 09194232038. You won't miss the shop as its along the SLEX. - tsikot.com
share ko lang mga pics:
si mang romulo...
driver side's power window mechanism...
left-rear-window naman... dahan-dahan, first time pa lang mabaklas...
September 29th, 2010 11:38 AM #38
"You are limited to using 5 images so please go back and correct the problem and then continue again." daw... kaya ito po continuation...
stuck up dahil sa kalawang...
pukpok... liha...
September 29th, 2010 11:40 AM #39
part 3 of 3 pics...
ito pala yung shop...
ako naman abala sa paglagay ng Elevo Power Window Lubricant dun sa mga rubber sidings.
November 3rd, 2010 11:04 PM #40
sir redeemed, thanks for your input regarding zaldy's. Dati pa ko naghahanap ng matinong gagawa ng power windows, eto pala meron na halos kapitbahay ko lang
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
