Results 11 to 20 of 80
- 179
June 19th, 2005 08:52 PM #12how long did it take for them to fix your window? diba they charge by the time it takes them to repair?
SiRaNeko
- Jan 2003
- 973
June 19th, 2005 09:44 PM #14
afaik, not time based. ako nga inabot ng closing e..ok lang at least na-aim correctly fog lights ko.
- Jun 2005
- 8
June 20th, 2005 04:35 PM #15Would you know of a similar shop na ganon din ka reasonable ang price sa south area? Paranaque, Las Pinas, Alabang, Pasay or Makati. Yung mga taga evangelista kasi parang manggagancho e.
June 24th, 2005 02:43 PM #16
thanks for the directions. medyo malayo pala. taga las pinas ako. baka may alam kayong a good shop that fixes broken power windows sa south??
If I have time, pupuntahan ko ang Wizzard. thanks again guys.
SiRaNeko
- Jan 2003
- 973
June 24th, 2005 08:26 PM #17got this from another auto forum. dont know if its kotse.com or Pex.
its a repair shop in buendia area..
hope this helps
Power window repair...
I have my rear door power lock and driver side window mechanism repaired this morning. The left side rear door lock is no longer working in auto power mode and have to engage/disengage it manually. The driver side window is out of alignment which damage the rubber on the window side and most cases the window is very difficult to open/close as the glass hit the rubber.
I brought it this morning (7am) at Zaldy's Trading located at the corner of apolinario st and SLEX extension near buendia. They found my door lock motor busted and they replaced it with exactly the same surplus unit. The window mechanism was aligned by balancing the glass riser. By 8am all is done and I paid 1,400. I recommend this shop as they knew what they are doing and understand the value of time as they assigned 2 of their technician to work on my rig. They gave me 3mos warranty and promise that they will not charge me should i have problem on their work during its warranty period. The shop specializes on power lock, power window, wiper and door lock for all kinds of car. Tel # 8439459, 09194232038. You won't miss the shop as its along the SLEX.
- Aug 2009
- 34
October 7th, 2009 12:24 PM #18sino ba may alam na pulido gumawa sa evang? anong shop name? san banda?
October 7th, 2009 12:35 PM #19
if you're from las pinas, you could have it checked at the autoshop along the road heading to the entrance of greenwood village. had mine fixed there several months ago and so far it's been fine
October 7th, 2009 01:13 PM #20
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
