Results 1 to 6 of 6
February 8th, 2013 05:45 PM #1
The getz does not come with it, but a dash light lights up when you are already overheating.
So i am planning to install an aftermarket one, para lang ma monitor kung tumataas temperature.
Wala namang problem sa oto, i just feel i need to be informed kung may problema.
Ubra kaya ito? Pano gagawin dito? Saan ikakabit yung sensor?
- Jul 2010
- 570
February 8th, 2013 06:22 PM #2Pwede iyan. Kabit lang iyan sa Ignition Wire connection para sa +12V supply at Ground connection. Yun sensor wire ay tap kung saan nakakabit iyon existing Temp Indicator ng kotse. Most Temp sensor ay sa intake manifold nakalagay.
Much better kung may mabili ka na may Temp Gauge na may audio alarm as warning. Minsan kasi mga visual indicator ay di masyado napapansin kung concentrated ka sa driving.
Meron ako DIY na Temp Gauge with audio alarm para sa Lancer EL Itlog. Twice na nailigtas ng overheat ang engine ko. Di na umabot ng sa pinakamataas dahil set ko ito na mag beep once lumagpas ng konti sa normal temp.
- Jan 2013
- 82
February 8th, 2013 06:41 PM #4Temp sensor for the engine is not on the intake manifold but somewhere along the cooling system usually near the thermostat. Temp sensor is in contact with the coolant and sends the signal to the temp gauge. There is a temp sensor in the intake manifold but it is used by the ecu to measure intake air temp.
- Jul 2010
- 570
February 8th, 2013 06:56 PM #5Meron yata nabibili na after market na Temp Gauge na may audible alarm. Yun nga lang hindi available locally.
Do It Yourself lang iyon temp gauge. Sariling ko design yun circuit. Isinama ko na yun Temp circuit alarm sa DIY Tachometer ko. Wala kasi nito sa mga Lancer EL Itlog na kotse.
- Jul 2011
- 262
February 15th, 2013 05:42 PM #6
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
