Results 41 to 50 of 70
- Aug 2013
- 112
January 7th, 2014 12:04 AM #41Tapos pagpalit ng starter, add relay pa! Ahahay! :D
Sent from my H100 using Tsikot Forums Mobile App mobile app
- 52,517
January 7th, 2014 12:19 AM #42your battery is slowly dying.
the fact that you can start the car by connecting it to another, presumably stronger, battery, is proof of this.
you can keep doing this for a few weeks more, or you can save yourself the trouble by replacing that battery now.
and for all you know, your car already has that relay!
we were push-starting our cars many years ago, because we "refused" to buy a new battery. we were students than; money was hard to come by, and we refused to ask funds from our parents. we saved up for it.Last edited by dr. d; January 7th, 2014 at 12:23 AM.
- May 2013
- 11
January 7th, 2014 12:36 AM #43Salamat po sa mga reply niyo mark1985, Flipo, at Chinoi!
Based sa mga replies pwedeng battery or starter or loose wirings/connection ang problem.
May marerecommend ba kayong shop dito sa Makati na pwedeng i-check ang mga yan at ma-diagnose ang problem? Malapit lang ako sa may Chino Roces & Dela Rosa Avenue. Pwede rin naman sa Banawe ko dalin pero kung meron namang shop dito sa Makati edi better kasi mas malapit lang at para kung magka-problema ulit or may backjob madali ko lang mababalik sa shop.
Salamat ulit ng marami in advance!
- May 2013
- 11
January 7th, 2014 12:42 AM #44Thanks for the advice dr.d! Ang iniisip ko kasi before dahil sinabi ng Motolite na okay pa yung battery ko (siguro about a month ago yung last na pa-check ko) baka hindi rin ma-address ang issue kung papalitan ko kaagad ang battery. Anyway, salamat sa suggestions. Ipapa-check ko nalang din ang starter just to be sure then palit ng battery.
- 52,517
January 7th, 2014 12:45 AM #45
- May 2013
- 11
January 7th, 2014 12:02 PM #46
January 7th, 2014 06:18 PM #47
- May 2013
- 11
January 8th, 2014 05:20 PM #48Ok na, battery nga talaga yung dapat palitan. Nagpunta ako sa 2 Motolite shops (different shop 'to sa pinuntahan ko a month ago) and parehas na chineck at dapat na raw palitan. Mali yung pag-diagnose nung Motolite na pinuntahan ko a month ago, sabi kasi dun ok pa raw yung battery kahit nag-jumpstart na ako para ma-start yung car. So, yun, bumili na ako ng battery kanina.
Thanks for the inputs guys!
- May 2013
- 11
January 8th, 2014 05:21 PM #49
- Nov 2009
- 22
March 1st, 2014 12:19 AM #50Hello Sirs/ Madam, same problem with me pag start ko ng car minsan it wont start on the second try it will start naman. So I decided to bring it to casa to have check, and I also let them check my fog lamp kasi according to their previous check di naman pundido yung fog lamp, rather it has something to do with the wiring. But unfortunately, di nila naayos yung fog lamp kasi modified daw and they need 2 days to have it fix. Same thing with the starting of my car which according need to replace na yung starter assy., but wala sila stock ng part (sabi nila surplus na lang daw).
Pag kalabas ng casa napansin ko na pag nag-full break ko feeling ko parang mamatay yung makina pero di naman namamatay. But on the 2nd day nung nag full break ako kasi mag u-turn ako bigla siyang namatay sa pag full break, pero nagstart naman. Ganon pa ren minsan sa unang start di siya nag start minsan nagstart naman, until on the sixth day start ko siya, nagstart naman then bigla namatay nakailang ganun. So after 15 mins. start ko nagstart then okay na di siya namatay, linabas ko siya sa garahe pero meron na ako naramdaman na parang mamatay siya, then after ng pag bwelta ko namatay nga siya, bumalik nanaman sa start then biglang namatay, so iniwan ko nanaman after 30 mins. okay nanaman inatras ko pa para igarahe na lang. After mga 5 hours pag uwi ko ng bahay start ko uli okay naman nagstart and di siya namamatay inatras at abante ko siya ng ilang beses di naman siya namamatay.
Ano kaya problema nito sa wiring or sa starter assy as what the personnel sa casa told me?
(I just bought my battery December 2012)
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
