Results 1 to 9 of 9
- Nov 2008
- 7
February 15th, 2012 01:14 PM #1Hi guys, I'm an owner of Toyota Vios first gen. Bigla na lang nawala yung headlight tsaka foglamps ko before I went home from office. Any idea kung problem ito sa fuse? Hindi ko rin kasi alam kung yung fuse box yung black na box malapit sa battery tsaka kung alin dun yung sa headlights and foglamps. Hoping anyone can help me...Thanks!
February 15th, 2012 01:21 PM #2
you could check it in the manual, may diagram and legend doon kung saan nakalagay ang fuse para sa headlights at foglamps.
- Nov 2008
- 7
February 15th, 2012 01:44 PM #3Problem ko sir, nawawala yung manual ko. Wala naman ako makita online...
February 15th, 2012 01:56 PM #4
- Nov 2008
- 7
February 15th, 2012 02:07 PM #5
February 15th, 2012 02:16 PM #6
- Nov 2008
- 7
February 15th, 2012 03:06 PM #8
try activating the headlight and the fog lights. while the switch is in the on position, check for voltage at the fuses. there has to be a bigger fuse (40amps) that feeds power to the headlight relay through the headlight relay and further feeds the LH and the RH headlight fuses. the fog lights are protected by a 15 amp fuse that feeds power to the fog light relay. check the power flow first. the weakest part of the circuit aside from the load are the circuit protectors (fuses, fusible links and circuit breakers). the 40 amp fuse is an autolink fuse (rectangular) and differs in appearance than the mini ATO fuse
February 16th, 2012 02:14 PM #9
a simple rundown on the headlight wiring: The 2 headlights (HL) are in parallel connection with each other. Then these 2 HLs are in series connection with the fuse and the power source (battery). same is usually true for the foglights....a simple wiggle of the wiring loom might do the trick. if it's not the load then it's usually the connections.
Suzuki JIMNY [merged threads]
