Results 1 to 5 of 5
- Jan 2009
- 38
August 15th, 2010 04:29 PM #1Mga sirs need your help po sa problema ng car ko. Unstable/low ang rpm pag inistart po. Ang reading is from 1000 to 500 then settle po sa 600. Base po sa nababasa ko po dito sa forum, dapat po yata rpm should be at 750. Car ko po is exalta 2002 a/t. Marami pong salamat.
- Nov 2009
- 456
August 15th, 2010 04:54 PM #2Kelan ang last tune-up ng sasakyan? Kung natune-up na at hindi pa din maganda ang idling...check/clean MAF sensor and idle air control valve (IACV). Also check the rubber hoses from the hydrovac, baka may butas or leak na pwedeng magcontribute sa erratic idling.
- Jan 2009
- 38
August 15th, 2010 05:28 PM #3
- Nov 2009
- 456
August 15th, 2010 11:23 PM #4Aside from changing the spark plugs, you also change the oil and oil filter. Clean (or replace kung masyado na madumi at maitim) the air filter element. Check/clean/adjust brakes. Also check and refill if necessary all vital fluids (transmission fluid, brake fluid, radiator coolant, power steering fluid, etc.)
- Jan 2009
- 38
August 16th, 2010 09:57 PM #5
