Originally Posted by
bambino
^^at idle, you must get at least 13v with headlights and AC on. to test
a rectifier assy ,i use a multimeter set at a diode range but it has to be out of the car.
to test a stator , visually check if its burnt out. set the multimeter at 10k range
check for short to ground and sweep test all four leads for continuity at 100 ohm setting.
there is an easy way of telling if the alternator is on its way out. with the engine running at idle all loads on , you hear a growling noise coming from it .that indicates your stator or rectifier assy is gone.
the hard way ,but its still easy, you have to take the alt out and open the back cover . now you will be able to test these parts.
i assume that you have a little bit of hands on , otherwise you have to bring that to an alternator shop for bench testing.
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
