Results 1 to 4 of 4
- Oct 2008
- 39
February 5th, 2010 09:22 AM #1mga sir question lang po meron po akong magnum stebel installed 1 pair sa car and 2 pairs sa suv. bakit po kaya parang mas malakas pa yung sound nun naka-install sa car kesa dun sa 2pairs na nasa-suv? 2relays din po ginamit sa suv with different wires on terminal 30. ang difference lang po na nakita ko is merong 20amps fuse dun sa terminal 30 nun nakakabit sa suv and yun sa car po wala pong fuse. does the fuse affects the sound? thanks in advance..
February 5th, 2010 11:32 AM #2
- Oct 2008
- 39
February 5th, 2010 10:45 PM #3
February 6th, 2010 04:20 AM #4
ATO is the blade type fuse with plastic body. the mini ATO is just a scaled down version, the plastic body is color coded as to the amperage rating. the fuse is your circuit protection, you can do without but without the protection in case there are problems that may arise on the circuitLast edited by jick.cejoco; February 6th, 2010 at 04:22 AM.
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
