Results 91 to 100 of 116
- 52,684
February 18th, 2019 08:53 AM #91
BANNED BANNED BANNED
- Sep 2014
- 8,492
February 18th, 2019 11:37 PM #92parang wala naman silbe yan product na yan, fate has sense of humor talaga, kung kelan mo hinde na fully charge backup mo, saka ka pa mawawalan ng baterya
motolite na lang talaga tawag na lang tumatanggap naman sila ng credit card
ang 5000mah, it takes 3 hours to charge. so 10000mah mga 6 hours to charge, eh yan 14000mah, so isang buong gabi na, yun eh kung yan lang iniintinde mo mag charge ng power bank sa gabi
ang mahirap di mo pwede itabi mo sa kama mo ganyan ka high capacity battery, pag bigla nasunog yan, hindi lang buhok mo sunog sayo habano natutulog ka
February 19th, 2019 05:22 AM #93
^May silbi naman..yung bayaw ko nakatulong sa taong tumirik dahil sa mahinang baterya gamit yan
- 52,684
February 19th, 2019 08:59 AM #94
- Mar 2014
- 686
February 19th, 2019 11:47 AM #95Yung sakin more than 6 months na di ginagamit, last check ko at least 90% pa ang charge. Nasa car ko lang lagi. Di ko na din nagamit nung finally e tinanggap na ng motolite warranty claim ko
February 19th, 2019 12:42 PM #96
March 17th, 2023 11:03 AM #97
anyone here who still uses one? can it really start your car?
Honda service told me medyo mahina na battery ko... haven't had the chance to personally test it (using a multi meter)
March 17th, 2023 11:35 AM #98
Wouldn't be using any jump starter on modern cars with electronics ... just have 24 hours battery delivery in directory ...
- Jan 2008
- 4,726
March 17th, 2023 12:02 PM #99multi-meter test is not enough.. may digital battery testers that measure internal resistance ng battery.. pag medyo mataas na, fail na sa test yan..
another measure is yung "load" tester.. bibigyan ng artificial load yung battery to test if mag hold ng voltage.. pag bagsak sa minimum.. soon to fail na yan
March 17th, 2023 12:29 PM #100
with unavailability of a load tester, you can disable the fuel system by removing the fuel pump fuse. crank the engine until it starts and stalls. then, with a reliable voltmeter crank the engine while observing the voltage of the battery under load. if the voltage drop below 11 volts, recharge the battery and retest. if the voltage still drops, replace the battery
this procedure applies to gas engine that has electric fuel pump
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
