Results 1 to 9 of 9
May 30th, 2013 01:12 PM #1
mga sir ilang relay kaya ang kailangan i add, kasi may 3 aux fan ung condenser ng liteace namin 1 sa rea rcondenser at 2 sa malaking condenser?
ang problema kasi mga sir palaging umiinit at natutunaw yung fuse kasi naka rekta na ata ung 3auxfan sa relay ng a/c.
pag hindi pagaganahin ung dalawang auxfan d naman natutunaw ung fuse d rin umiinit.
May 30th, 2013 01:20 PM #2
if you are having fuses blowing, you have an option of changing the fuse to an in-line self resetting circuit breaker (ATO type) or you can modify the wiring ( your car will be a few ounces heavier) by adding dedicated control wires and power circuit wires to each condenser fan
http://www.google.com/url?sa=i&rct=j...69974074656511
http://terminalsupplyco.com/Store/De...spx?CAT=CB2010Last edited by jick.cejoco; May 30th, 2013 at 01:24 PM.
May 30th, 2013 07:06 PM #3
sana may nabibiling ganyan d2 sa province pero kung wla ilang relay ang kailangan idagdag mga sir?
isa lang kasi talaga ang stock na auxfan ng liteace pero dnagdagan ng dating may ari pero d kasi siya nag add ng relay kaya palagi na tutunaw fuse at anung size ng wire ang kailangan ilagay mga sir?
May 30th, 2013 07:31 PM #4
May 30th, 2013 09:22 PM #6
Boss, use the same size as the wire that comes out with the fan assembly. by the way, i think this came out wrong correct ko lang onti sir. pero mukhang nagetz mo naman eh.
"To be safe, 3 fans 3 relays, with 3 different wirings. then tap it all to the triggering supply of the AC same to the original. Parang sa busina or headlights lang yan Sir.
- Nov 2009
- 3,484
May 30th, 2013 10:28 PM #71 relay for front, 1 relay for rear, remove the original relay.
Install 15A fuse for the mains(going to the battery) of rear relay, then 20A fuse for the front
Use 40A contact relay, gauge 12 stranded-wire for the mains, while gauge 16-18 will do for the relay coils.
September 15th, 2013 01:41 PM #8
- Jul 2010
- 570
September 16th, 2013 02:18 AM #9Mas maganda ay tanungin mo yun Auto supply na bibilhan mo ng Relay. Meron kasi ampere rating ang busina at headlamp o foglamp. Alam nila ang dapat na relay na tamang ampere rating ibenta sa iyo. Sabihin mo lang kung saan gagamitin. Kung busina or headlamp.
Daming issue ng SU7:grin:
Xiaomi E-Car
