Results 651 to 660 of 754
July 20th, 2013 06:37 PM #651
Hi Sir. I followed your advise to have the battery charged then see if it holds up for a week to find out if the battery is the problem. But motolite does not want to charge it anymore. Hay! I am not sold on their explanation that the battery cannot be charged na
- 52,701
July 20th, 2013 06:56 PM #652with a voltage drop like that, i'll believe them that i need a new battery.
even dying batteries can hold a charge sufficient large to enable you to re-start the engine if you do it "soon enough". but they can't hold onto that charge for a "long time" (as in, overnight).
syangapala.. what did they say about the alternator? if the alternator's ok, then it most probably is the battery.Last edited by dr. d; July 20th, 2013 at 07:01 PM.
July 20th, 2013 06:57 PM #653
July 20th, 2013 07:02 PM #654
Sorry, I was not able to have the battery charged at all because when I brought it to Motolite, they refused to charge it kasi when they put the clamps it was on the green zone (12.5) then when they twisted the knob on the tester it dropped to 7 daw.
But the corolla gets started everyday pero it gets weaker as days pass then after a week, dead na. Pero when I used the jumper cable umandar naman. I turned it off after removing the cable then it started again.
- 52,701
July 20th, 2013 07:11 PM #655hija, ganito na lang:
jumper it and start it.
then use the car so the engine can charge the battery.
when you get home, disconnect the battery.
re-connect after 2 , 3, or 5 days. if the car doesn't start, it's time to get a new battery.
July 20th, 2013 07:14 PM #656
July 20th, 2013 07:19 PM #657
its pretty hard to judge since nauubos kagad yung battery. I think namatay plate yung nadiskarga. pwede nagkataon lang na pabigay na yung sa altis battery or talo sa charging. best is to torture test the battery.
let the corolla run for 30mins, go around your village or something without electrical load. let the car rest for 3 to 5 days. Start, kung mahina redondo, battery na. pero kung malakas redondo, talo sa charging. you mentioned na umilaw yung batt sign dati, baka nagloloko na ic ng alternator.
- 52,701
July 20th, 2013 07:30 PM #659glad you like it!
2 km is fine. just don't you use the aircon or the lights, so the alternator output goes only to the battery. and if the engine dies, start it right away. it'll start.
we don't have to fully charge the battery. we are just testing the battery's ability to hold charge.
July 20th, 2013 07:34 PM #660
