san nakakabili nun, may specifics ba sa ganun? 97 pizza
stick with OEM. i read an article comparing splitfire, oem and another aftermarket brand, best performer parin ang OEM.
Meron naman nabibili nun. Usually larger diameter than stock. If you really want it for cosmetic purposes, ok lang. Wala naman siya masamang effect AFAIK.
Merong blue and pink among other colors. Nakita ko sa isa pang Vitara ng 4x4ph.Yung Pizza pie dati ng pinsan ko naka larger HT wires din. For looks lang naman. 1.5 A/T yung unit niya.
ingat lang pagbili ng HT wires baka magka static radio nyo hala kayo. better stick with the OEM hindi naman nakadisplay HT wires kaya no need to porma
dati nauso iyon transparent naman na HT wires at ang distributor cap
problems with high tension wires, nakow, baka di na lang, pakulayan ko kaya ung engine? hehehe
Ano ba 1997 pizza mo?EL?Glxi?
Sa kapitbahay ko wala naman naging problem naka 3-5 years din ang Hi-Tension niya ang naging problem lang niya ay nasira yung splitfire niya nagkaroon na butas kaya pinalitan na niya.
ok din pero mukhang dagdag linis lang iyan dahil kitang kitang ang dumi dyan.
Sa suking auto supplies, personally nakakahinayang ang oem unless
sira na. if you want looks, match it with electroplating.
If you're going to buy aftermarket high tension wires, don't settle for the cheap crap. I've had Chinese wires (one really cheap set, and one set that cost about as much as Splitfires and came in a fancy box) give out in less than a year (mad crossfiring).
The best really is OEM, but if you have to buy, please don't buy the cheap ones... magsisisi ka lang.
A little OT:
Akala ko high tension wires are those wire sa giant electical structures. Kailan kasi high "TENSION"....o hila.
But after checking the good ole dictionary, tension could also mean voltage pala. English is a strange language![]()
