Results 1 to 1 of 1
- Feb 2010
- 71
August 1st, 2011 09:54 PM #1Happened after troubleshooting the aircon system. The reserved oil flowed down to the engine. After removing excess oil, there's an electrical sound of contacts being shorted like placing a battery terminal to the terminal post sa main fuse box. And lately motor seems to be pumping but oil level is consistent in the tank. Nag ok siya 5 hours ago pero me time pag idling biglang engine off then electrical sounds. I managed to kalogkalog the connector to the motor then ok na di na namamatay makina pero one in a while siguro pag me nagagalaw due to movement /vibration , namamatay uli then the electrical short again.
for now, disconnect ko muna battery.
