Results 11 to 18 of 18
May 4th, 2012 06:32 PM #11
May 4th, 2012 06:40 PM #12
your car needs BCI group 35 or 350 CCA at minimum. your starter ranges from 60 to 100 amps current draw depending on which starter model. the 350 CCA should suffice or you can slightly increase the CCA rating slightly as long as the physical dimensions match
- Mar 2012
- 34
May 5th, 2012 08:51 AM #13*shadaow
same size sa standard battery yung motolite endurance same size lang plano ko sna ilagay sa likod para hindi bumigat sa harap...sabi kasi nang kaibigan ko maganda raw kasi 19 plates tapos compact
May 5th, 2012 09:18 AM #14
Electron brand will do. P1,800 lang dati..palit luma, 12 months warranty.
It lasted 2 years sa sentra ko dati.
- Mar 2012
- 34
May 5th, 2012 10:22 PM #15
- Mar 2012
- 34
May 5th, 2012 10:39 PM #16
June 6th, 2012 11:30 AM #17
what model is the CSB battery(group or series)? is it designed for an automobile? i know csb bats are used on UPS, didnt know they have a model for automobile. check na lang sir bka hindi safe for auto use.
- Nov 2009
- 105
June 21st, 2012 02:19 PM #18mga sir, question, pwede ko bang palitan ng 2smf ang stock 1smf battery? ang oto ay automatic na 2.0L lang. no accessories. tiningnan ko ang lagayan kasya naman. may speaker kasi ako na never nagamit (motolite enduro 2smf). thanks in advance
Monk-owned R53
