Results 11 to 11 of 11
July 28th, 2015 05:07 PM #11
yun ang problema no idea kung saan yung negative side ng ignition coil maski injector driver
Any of the four injector drivers. There are only two wires connected to your injectors. One wire is HOT with ignition switch on. The other wire is the driver coming from the PCM. Use a DMM (digital multi meter) to reduce the risk of frying your PCMLast edited by jick.cejoco; July 28th, 2015 at 05:11 PM.
