Results 21 to 24 of 24
- Jan 2005
- 445
May 23rd, 2011 07:40 PM #23155 watts / 12 volts =12.9 amps so 10 amps is not enough.
Another thing if you placed a higher watt head lamp on a stock wiring magkakaproblema ka
1. sobra magiinit ang terminals kaya possible na masunog.
2. sasabog fuse
3. mag iinit wiring.
May 24th, 2011 12:32 AM #24
Using the stock wiring and terminals with high wattage bulb, this is very dangerous. The plastic terminals may melt due to the heat created by the almost 3x more wattage. The heat will be triple but the light output is not triple. You need to convert to ceramic terminals. The wiring must also be upgraded to thicker guage, the tiny stock wires is going to overheat and will melt the wire casing, this then can get in contact with your chassis and will most likely short out not just the headlight but your entire electrical system.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
