Results 1 to 5 of 5
- Feb 2013
- 42
June 17th, 2013 09:45 AM #1Hello po mga katsikot.sasakyan ko toyota liteace 2c-turbo.bagong top overhaul kc napaoverheat.problema ko po ngaun pag cold start sa umaga,ayaw umandar kung hindi mu irekta ung baterya sa glowplug nya.pag switch ko umiilaw naman ung heater indicator sa dashboard tapos pag nag off ilaw nya at istart ko ayaw umandar.parang di nya napapagana ung glowplug.pag irekta ko naman oneclick start agad.ano kaya problema dito at ano mapalitan na parts.okay naman ung baterya at mga glowplug.salamat sa mga inputs nyo dito.
June 17th, 2013 11:52 AM #2
- Nov 2009
- 3,484
June 17th, 2013 12:14 PM #3To verify a worn glow-plug relay contacts without using ohmeter, temporarily bridge the terminals of contact using gauge 10 wire - then after 4-5secs start the engine. If engine starts, remove the relay and inspect/ clean/ repair/ replace. Check also grounding-wire of engine block for possible poor/ corroded contacts. Dont forget also to check the very basic - Glow plug mains fuse.
- Feb 2013
- 42
June 17th, 2013 02:23 PM #4Ok sir un nga tinoro sa akin nang mekaniko ko para umandar sa umaga sabi nya ok daw mga glowplug at ung wire na lng muna gamitin para gumana heater nirerekta ko from +terminal baterya sa dulo nang glowplug idikit ko 3s to 5s tapos start.andar na agad.sir pwede b malaman kung san nakakabit ung heater relay para matingnan ko kung kaya ma DIY malinisan o mapalitan.salamat bka sakaling may makapagturo.
- Nov 2009
- 3,484
June 17th, 2013 02:42 PM #5I assume that's JDM liteace LHD converted since 2ct engine mo. Check mo fuse/ relay box may nakasulat doon kung saan ang glow-plug relay/ fuse. If not, try mo sundan yung wire ng heater, usually hindi lalayo yan sa engine bay at relay since high current circuit ang heater. Palagay ko relay or fuse lang yan since umiilaw kamo ang heater timer sa dash w/c means may signal going to relay.. Makakatulong kung may tester ka, at kung hindi mo kabisado patulong ka sa auto electrician.
chinchilla fur vest leatherjacketback
Verifpro - paypal, ebay, banks, crypto, docs and...
