Results 11 to 15 of 15
March 13th, 2014 02:29 PM #11
Newer cars use modular door latch/actuator assemblies with the motor+gears and electronics built-in. I recently replaced the front-right door latch because the actuator motor no longer produces enough force to engage/disengage the lock. This is on a 07 Honda Civic.
I did this DIY using a replacement module I bought from eBay.
This is the defective door latch/actuator assembly.
March 13th, 2014 04:26 PM #12
On a pal's civic, we fitted a universal actuator. Para madali na din palitan in the future. Plus, we use the other actuators on the other vehicles. Hehe
March 13th, 2014 05:18 PM #14
Not easy to do in my case. The newer Hondas, as well as others, use cable-type linkages so there's no way to attach a universal actuator without extensive modifications.
If the vehicle use push-pull metal rod linkages to operate the locks, a universal actuator can be used as there's a place for it to anchor to.
Suzuki JIMNY [merged threads]
