Results 11 to 19 of 19
October 15th, 2018 11:53 PM #11
- Jan 2014
- 54
October 27th, 2018 09:27 PM #12Mas better ba ang WD-40 sa car door hinges? Parang mas madaling nakaka attract ng dirt ang WD-40.
I don’t know the exact name but yung electrical latch or connectors ang madaling mag crack. Hindi yata enough ang electrical tape. It’s also difficult to wrap the connectors with electrical tape.
- 52,514
October 28th, 2018 12:24 AM #13
October 28th, 2018 12:36 AM #14
HHS-K
Description
16.9 fl. oz. Aerosol
Versatile lubricating oil due to its combination of *balanced, matched properties.
Features
High-pressure resistant
- Extraordinarily tear-resistant lubricating *film with outstanding noise and vibration * damping properties
High creep capacity- Excellent lubricating properties with close tolerances. Reliably protects against corrosion.
Active adhesive effective
- No throwing off of the lubricant with turning and rotating parts
Good material compatibility
- Compatible with rubber and plastics. Behaves neutrally toward painted surfaces.
Splash and saltwater-resistant, withstands weak acids and alkaline solutionsBr>Contains no silicone, resin or acid
Operating temperature range: -23?F to +672?F (Temporarily: +737?F)
Color: yellowish
Application
Door hinges
Pressure resistance under high pressure loads
Despite high pressure loads and the shear *movement of the base body, the lubricating film of the HHS-K remains active and does not tear off. Reliably separates the opposing body from the base body, ensuring optimum *wear protection under high pressure loads.* This is only possible with dirt-free lubricating points
- 52,514
October 28th, 2018 12:40 AM #15..."only possible with dirt-free lubricating points..."
i guess that rules out door hinges.
technical doubletalk.
October 28th, 2018 01:10 AM #16
- 52,514
October 28th, 2018 01:15 AM #18
- 52,514
October 28th, 2018 01:19 AM #19
Traffic!
