Results 1 to 2 of 2
August 26th, 2012 08:49 PM #1
Just installed an electric oil pressure gage Circuit Brand (black faced) OEG-12V paired with a Torica OU-101 12V oil pressure sending unit.
Gage reading sweep from 0-10 kg/square meter:
0-2 start
2-6 normal range
6-8 check
8-10 over pressure range
Oil pressure sensor have one terminal only (not the floating type)
I wired the gage terminals given the following using 18 AWG wire:
S - wired to oil pressure sender terminal
G - wired to a body ground within the dashboard
I - wired to a 12V source on the ignition switch when switch is ON.
Now, the problem is:
Gage reading initially was 6 kg/sqcm. Revved the engine and the needle would go down to 3 or 2 kg/sqcm. Upon release of the pedal (decreasing rpm), pressure reading would rise near the max reading of 10 then goes back to 6 kg/sqcm.
after some warmup, gage reading was at 8 kg/sqcm. Revved the engine and the needle would go down to 6 or 4 kg/sqcm. Upon release of the pedal, needle would shoot past the max gage reading of 10 kg/sqcm then go back to 8 kg/sqcm.
as per my knowledge and experience with mechanical oil pressure gages, oil pressure would rise when engine is revved. idle oil pressure is 0.7 kg/sqcm (10 psi). but my electric gage behaves the other way around.
did i miss something? please help. maybe sensor is not compatible with the gage but it's still a guess.
any input or comments is highly appreciated.
August 27th, 2012 03:10 PM #2
did some testing lately:
Oil Pressure Sensor resistance is 55 ohms even when engine is revved but voltage varies from 4.12 - 9 volts.
Gage voltage with Key ON, Engine Off:
S - G : 8.4 volts
S - I : 4.5 volts
I - G : 12.5 volts
gage reading is beyond the maximum. same effect when the sender terminal is shorted to ground
Resistance tests (all readings in ohms):
With G connected, I disconnected, S connected:
S-I: 101
S-G: 44
I-G: 145
With G connected, S & I disconnected:
S-I: 101
S-G: infinite
I-G: infinite
With G connected, I disconnected, S shorted:
S-I: 101
S-G: 0
I-G: 101
With G disconnected, I disconnected, S shorted:
S-I: 101
S-G: infinite
I-G: infinite
With all terminals disconnected:
S-I: 101
S-G: infinite
I-G: infinite
Last night, oil pressure ay lumalampas sa maximum kapag nagdedecelerate ang engine.
sorry too long at siguro medyo confusing. hope somebody can relate. tia
Since yung spare tire nasa labas ng sasakyan. Ano tawag dun sa lock na nilalagay sa spare tire para...
