Results 21 to 24 of 24
- Feb 2014
- 2,533
July 27th, 2018 01:58 PM #21well if that's an ecosport w/ the infamous dual-clutch tranny then you certainly don't want to disconnect the battery completely. for some stupid reason the tranny computer loses its firmware when you disconnect the battery and it'll have to be reflashed at the casa
- Oct 2012
- 4,851
July 27th, 2018 02:09 PM #22
July 27th, 2018 03:29 PM #23
- Dec 2018
- 5
December 12th, 2018 02:07 PM #24If you have a Ford, you can get OBD Link MX from Amazon, load Forescan Lite from the internet to your smart phone and read and reset all the trouble codes yourself. Disconnecting the battery can shut off the low beams in some Fords especially Rangers, cause shift problems and shut off the automatic up and down on the driver's window.
If you have a Toyota it will reset all the programs to original settings. If you have a Camry that is speeding up by itself, disconnect the battery for at least 2 hours 2 times to fix the problem.
Varta used as replacement battery in German cars ... but they cost double that of Motolite ... not...
