Results 41 to 46 of 46
September 7th, 2009 08:50 PM #41
Kung may extra budget, I'd go for Motolite Excel. More than 5 years ang inabot sa akin nuon. Pero if wala gano budget, OK na ang Outlast (yung hindi maintenance-free).
September 8th, 2009 12:39 AM #42
gamit ko motolite excel(green), mga 1 and a half year na siya and recently having symptoms and problems na this past few months,
last june(pasukan), hard starting and till this past Friday Sept 4, thrice lang nag click, kahit redondo wala. then clutch start(apak clutch to assist the starter to ignite fuel and rotate the flywheel without the load of the transmission) ayun nagstart na...
pinagtataka ko lang, bakit nung nag clutch start ako, nagstart makina ko?
add ko lang, ganitong symptoms yung mga naramdaman ko nung naka stock battery pa lang auto ko (motolite gold) pero past 3 yrs ang tinagal.
and question din pala, im using 1sm type battery recently, im planning to upgrade to 2sm battery, is it appropriate for me to use 2sm batterry on my engine that is intended for a 1sm battery?
- Apr 2009
- 536
September 8th, 2009 05:07 PM #43it depends kung fit yung 2sm sa battery case ng car mo, i mean if it can fit i think its better. you'll see if you use 2sm it will last longer and pag gipitan na may ibbigay pa.. same lang naman yan 12 volts din, just have more capacity. parang yung battery ng laruan may AAA, kung kasya lang ang AA it can work better and longer.
- Apr 2009
- 536
September 8th, 2009 05:17 PM #44it depends kung fit yung 2sm sa battery case ng car mo, i mean if it can fit i think its better. you'll see if you use 2sm it will last longer and pag gipitan na may ibbigay pa.. same lang naman yan 12 volts din, just have more capacity. parang yung battery ng laruan may AAA, kung kasya lang ang AA it can work better and longer.
September 8th, 2009 05:19 PM #45
September 8th, 2009 06:02 PM #46
wah bulok motolite excel ko! bumigay ngayon tanghali! naka 2sm motolite gold ako now for temporary use only, sa owner type jeep namen kase yun...going to bring it sa dealer this week, hinahanap pa resibo...kainis sa istorbo talaga!
2years ba ang warranty period ng motolite excel 1sm? tama ba nakita ko sa isang post dito?
