Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 83
    Jul 2018
    #51
    yes ang hirap! mobile phone and bluetooth speaker ang pansamantagal
    bring the car to a proper auto electrician, where it can be properly trouble-shot.
    personally, i find it difficult to drive around without in-car entertainment and lights.
    your cigarette lighter is probably also out.
    May 2018
    #52
    Quote Originally Posted by red_one View Post
    I use in-car voltmeter for monitoring voltages and have an automatic car battery charger desulfator for maintaining battery health at home.
    Sent from my ASUS_X00DDA using Tapatalk
    ano po ba dapat ang reading ng voltage nito? before and after magstart?
    Aug 2012
    #53
    Quote Originally Posted by techglimpse View Post
    Before start = 12V and up.
    After start = 14V and up.
    Sent from my ASUS_X00TDB using Tapatalk
    #54
    When cranking, pag umabot ng 7V, palit ka na.
    Jun 2005
    #55
    Quote Originally Posted by istan View Post
    Actually, 9v lang palit kanna dapat. At 7v, swerte mo na magstart pa yan
    Sent from my MI MAX 2 using Tapatalk
    #56
    Sa cranking lang naman, bumabalik sa 12V agad pag nag start na.
    Normal start sa akin 9V.
    May scangauge kasi ako.
    Jun 2005
    #57
    Ah. You use them obd testers. Afaik there are some delay in the reading there.
    I use fluke true rms multi tester that records the highest and lowest voltages down to in millivolts and time recording.
    #58
    actually maski 9v ang binaba pag starting, alanganin nag condition ng battery mo bro.
    try mo muna i charge batt to full, then remove float charge; test crank ulit
    #59
    before starting, that's your battery voltage.
    after starting, and with the engine running, you are now measuring your alternator's output voltage.
    #60
    Sira ang charging system/ alternator mo.
    After starting, Vo should be at charging voltage = 13.8V.
    Kung 12V yan at cranking at 7Vdrop, battery lang ang tumatrabaho.
    Have your alternator checked asap if you don't want to ruin the battery.
Battery drain.
