Results 21 to 26 of 26
July 25th, 2012 09:44 AM #21
sir ang problema mo eh hindi sa alternator or sa battery... ang problema mo grounding.... mag add ka ng additional ground sa battery to the body.... at magdagdag ka din po ng pos. wire sa battery going sa alternator..... ayan po ang sakit ng karamihan ng sasakayan pag nag kaka edad na... check mo yung ground cable attached to the body baka loose na or madumi or makalawang...
July 25th, 2012 09:47 AM #22
Seems the alternator is working but the charging is not as it used to be. My suggestion is not to use the aircon immediately after starting your car, let it idle or drive away for 2 mins before using the aircon. Then at night after a trip, turn-off the HL's and AC then let the car idle for 1-2 more minutes before shutting it down.
July 25th, 2012 10:06 AM #23
August 12th, 2012 10:14 AM #24
normal charging for an alternator should be
without load. ( meaning NO lights, aircon, stereo, etc)
idle - 13.4 volts
* 2000 rpm - 14.4 volts
with load ( ON lights, aircon, stereo, etc.)
idle - 13.4 volts
yes sir it could be because of the headlight... better have the battery checked might also be time to get it replaced... usually a isuzu crosswind has a higher capacity requirement, so the battery must be able to cope up with the demand... try getting at least a motolite gold, or excel 3SM-N70L,
August 31st, 2012 09:54 PM #25
Sirs, a related question please. yung usually alam po natin is tatakbo yung car pag na start or jumpstart na ito at ok yung alternator (normal output as per voltmeter) even with a nearly dead battery (10 volts as per voltmeter) kasi in theory alternator na nag susupply ng electric needs ng engine. pero yung sa akin po ay namamatay after idling for a while at about 900 rpm, aircon off. nang ni rerev ko po ito neutral at around 2000 rpm pag bitaw ko ng pedal derecho din namatay. btw, gas engine po ito avanza 1.5 AT and ok na po sya after simple palit ng battery for about 5 months na but i still cant shake off the feeling na may ibang problema dahil hindi tugma sa alam ko yung nangyari. What went wrong po kaya? di na po ba true yung theory now? at ano po ba maaring pag kakaiba kung crdi or old school diesel pag uusapan? TIA sa mga sagot
October 3rd, 2012 09:44 PM #26
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
