Results 1 to 4 of 4
- Feb 2012
- 1
February 14th, 2012 12:36 AM #1Hello guys, need help,
Toyota corolla Big Bidy 97 XL ang tiskot ko.
Bagong linis ang starter at Malakas ang battery.
Pag start ko walang wala maririnig kahit tick.
Pag disconnect ko at reconnect ko ang ground sa battery, mag start na tsikot ko, na parang walang ka probleproblema.
Pag nag park ulit ng matagal, ayan nanaman di nanaman mag sstart unless disconnect / reconnect ang ground sa battery.
Wala computer box ang tsikot ko, at wala rin neutral sensor.
Help! Maraming Salamat!
February 14th, 2012 01:26 PM #2
revisit your starter again, it might be loose on the engine block or the terminal 30 cable is loose on the solenoid bolt. if it did not have this symptom prior to the removal of the starter, repeat the process of removing and reinstalling the starter. if the brushes are worn out, this will cause an intermittent crank/ no crank problem.
February 14th, 2012 01:30 PM #3
sir usually old model cars has grounding problems... lagyan nyo po ng extra ground yung starter nyo papunta sa battery... use battery cable sir...
February 14th, 2012 01:40 PM #4
Monk-owned R53
