Results 1,931 to 1,940 of 2247
August 15th, 2020 09:40 PM #1931
Mag wa one year nana amaron hi life ko, from amaron GO user 3 years 6 months lifespan, hindi ko pa na experience sumabog battery ko.
August 16th, 2020 12:08 AM #1933
August 16th, 2020 12:58 PM #1934
The warranty on mine will end in 10 days. It's still 100% SOH and I thought I'd give it some TLC.
PRECAUTIONS:
1. Wear safety glasses (I used glasses and a face shield)
2. Wear safety gloves
3. Use non-metallic prying tools (I used a plastic prying tool designed to open mobile devices)
I undid the caps and I can see that the electrolyte levels are still ok. Though the crud build-up after 21 months needed to come off.
I washed the caps with soap, thoroughly rinsed with water, and then dried them off completely with compressed air. FWIW, I believe the caps have a regulating valve inside. Nothing sophisticated but I think it just prevents gasses from venting out. It sort of works like your radiator cap and as a safety precaution, it will/should start venting when a certain pressure is reached. I think that dirt build-up can clog or cause this vent to stick which could prevent gasses from escaping when it needs to.
I did my best to clean off most of the dirt under the caps using paper towels, careful not to let them fall into the filler holes. I then put the cap back on but not entirely inserted while I give it a maintenance charge for a few hours.
- May 2017
- 2,099
August 16th, 2020 05:01 PM #1935Tanong lang, if you are not going to use your car for 3 months, is it okay to just remove the negative terminal so as to conserve the energy in the battery? Tapos I plan on just recharging the battery at least once a month by a 15-20 minute charging then remove the negative terminal again.
Would this be okay without any repercussion to the car's electrical components?
August 16th, 2020 05:09 PM #1936
- 52,698
August 16th, 2020 06:31 PM #1938
The indicator showing green means battery is ok, and no refills (distilled water) required. Inside the indicator there's s small green ball that floats to indicate battery is fine. In case the indicator show silver/clear means battery needs charging or refills of distilled water
August 16th, 2020 06:59 PM #1939
I'd remove the whole battery then hook it up to the charger if I'm gonna be away for more than 2 weeks. If less than that I'd just remove the negative terminal right after charging. Ang ayaw ko lang yun settings marereset ulit.
Has anyone used one of those car memory savers?Last edited by Wh1stl3r; August 16th, 2020 at 07:02 PM.
- May 2017
- 2,099
August 16th, 2020 07:24 PM #1940
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
