Results 1 to 8 of 8
October 14th, 2002 09:25 PM #1
Ey guys need your help.
This is not a problem for me actually but it sometimes is annoying. Ung headlights ko kasi and other electronics, napapansin ko, may very slight change (lumalakas ang mga lights) kapag inaapakan ko ang silinyador. Is this related to my alternator. If i remember it right, dati na itong problem na ito and im hoping na makakahagilap po ako ng solusyon dito.
My ride nga pala is a 96 L200 (ang stock alternator niya is 60 amps yata, but i replaced it with a pajero alternator). Salamats po :roll:
October 17th, 2002 05:43 PM #2
sabi nila battery daw yan eh try to check your battery and connections. check mo rin kung may tubig pa battery mo. pati ground connections ng battery paki tingin na rin.
October 17th, 2002 05:55 PM #3
if you replaced your alternator already.....try checking your battery and your wiring........:D
- 230
- 23
October 25th, 2002 08:44 AM #5naging prob. ko rin yang simula nung nagpa-setup ako sabi sa akin sa TIERODMAN dito sa Mkti yung alternator kaya nagpalit ako from 60 AMP to 80 AMP... OK naman, after 1 week bumalik yung prob at naging mas grabe pa kase namamatayan na ako ng makina at ayaw nang mag-start then pinacheck ko ulit, yon palit ako ng bagong battery ngayon ok na sya...
October 26th, 2002 12:39 PM #6
Djerms,
Check mo kung hindi ka overcharging. Ganyan Besta ko dati. Prito sockets ng headlamps sa lakas ng overcharge. Ka-boom pati alternator.
- 8
October 26th, 2002 04:02 PM #7tulong naman i have a problem i dunno kung sa alternator or sa baterry or sa regulator na ang sira lagi na lang na discharge baterry ko sa palagay ko di nag charge yung alternator pano ba ma check kung ok pa yung alternator pati yung regulator?ano ba proper way na pag check kung okay pa,pati yung pag check na rin ng baterry kung ok pa?
thanks in advance!!!
November 13th, 2002 12:05 PM #8
lups,
pa check mo muna battery mo baka may patay na cell kung ganon lagi talaga discharge yan, kung ok naman battery pa check mo yon alternator baka kakac sira na diode na sa loob.
