Results 31 to 35 of 35
January 23rd, 2009 02:42 PM #31
yup kaya nga dapat lagi nyung i-check if the alternator still operates from 12.1-14.5V dun lang...
pag humigit sa 14.5V sira na yung IC regulator, pag di kumarga, either yung stator or rotor ng alternator needs rewiring na...
mas ok kung pa-rewire nyu ang old alternator nyu, kasi mas mura, and its like buying brand-new.. pag gusto nyu ng masmalaki, get a surplus, max of 90AH para di ka magkaproblema sa stock wiring.
akin, hehehe, at full load-12.5V, minimal load-14V hehehe...90ah min, 120AH max...walang bitin, nakalimutan ko yung foglight na buhay for 1 day, na full discharge, kinadyot, tumakbo, mga 30 mins drive lang back to normal na...as if walang nangyari hehe
January 23rd, 2009 03:14 PM #32
mga sirs related po ba ang engine heat sa alternator.napansin ko kasi after repair/rewinding the alt. bumaba temp. gauge.before almost 1/2 siya w/ acon on, may thermostat at running at high noon, ngayon the max. is 1/3.pasensya na a newbie question. btw the alt is 50A.
January 23rd, 2009 04:22 PM #33
baka kasi malamig lang ngayon... and/or noon baka alternator mo ay dragging the engine
February 11th, 2009 03:07 PM #34
malas talaga, battery is new(2mos.) pa and its boiling acid leak thru the one side of the engine bay,try another batt. nag leak parin.pina check ko overcharging daw alternator sa battery,bagong rewind yun but we did not replace the IC,so IC ang palitan.is it worth to replace the IC or just buy a surplus alt? magkano ba IC?
- Oct 2008
- 469
February 11th, 2009 10:36 PM #35mga sir pasingit po. Ano po ba mga symptoms na kailangan na ipa-rewire ang Alternator and starter??
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
