Results 1 to 7 of 7
- Jan 2012
- 3
January 29th, 2012 10:32 PM #1mga bossing good pm need your help advice/suggestion
ang problem ng tsikot ko is walang lamig yung aircon and nag-ooverheat tapos umaandar yung auxillary fan to the max speed. pero kapag nakapatay ung aircon nakakaandar naman ng maayos ung car. and kahit na naka on na yung ac button wala pa din lamig ang diagnose ng mechanic malapit sa amin is yung line or wiring ng computer box papunta sa compressor wala daw dumadaloy na kuryente. Ang solution daw gagawan ng bagong linya hindi na daw padadaanin sa computer box para kapag naka on na daw thru fan speed(1,2,3,4) diretso lamig na daw no need na para i-push yung ac button. they check for leak test, compressor, radiator, freon and etc. wala naman daw problem ang sabi may part daw na nasira sa computer box like ic transistor, or diode. Ang sabi nila yun daw ang pinaka okay na solusyon kaysa daw bumili ako ng new computer box kasi natatakot daw sila na magalaw ung computer box ng tsikot ko and para daw makatipid na din. Help mga sir sa car aircon specialist po ba dapat ako pumunta or sa car electrician. Any recommended na shop na reasonable naman ang singilan. Need other advice help lang mga bossing ng matapos na problem ko.
- May 2011
- 481
January 30th, 2012 08:08 AM #2
from your description, the "mechanic" does not have the know how nor the skill to properly diagnose the problem of your air conditioning system. take it to a specialist. habit has it for incompetent "mechanics" that the computer is always to blame. it might also help if you properly identify your car make, make, model, odometer reading and the last thing done to the air conditioning that you can recall
February 11th, 2012 01:45 PM #3
ayos din manghula yung mekaniko mo. dapat check nya muna kung me refrigerant ang system mo, most ac system ngayon ay hindi gagana ang compressor kung walang refrigerant ang system mo kaya sabi nya ay walang kuryente pumupunta sa compressor.
February 11th, 2012 02:11 PM #4
February 14th, 2012 01:46 PM #5
bossing ano po car ito?, year ? this info will be a great help to diagnose your a/c problem
- Jan 2012
- 3
April 2nd, 2012 09:21 AM #6just went to Canpro Auto Specialist sa Las Pinas problem is now fixed sobrang professional tao dito mismo may-ari ang nagaayos just took 2 days and got it fixed worth ang pagpunta ko galing pa ko ng qc.
April 2nd, 2012 02:04 PM #7
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
